Walkert20
Mar 05, 2018Aspirant
New router
I have changed my routers name but when I look at selected devices. I still see a netgear37 5g. What is this? Why is there two different modems to choose from and is my password the same for both of t...
- Mar 05, 2018
Walkert20wrote:
I have changed my routers name but when I look at selected devices. I still see a netgear37 5g. What is this? Why is there two different modems to choose from and is my password the same for both of them?Not sure what you are saying?
Off hand if you are seeing BOTH the old name and new name for the router, just how and where are you seeing this? What 'program'? What OS?
If you see 2 different SSID's, and the one with 5G is the one you are questioning, that is the GUEST SSID I believe.
Password the same? Are you using SMART CONNECT?
Sort of sounds like changing the NAME of the router forced some other settings changes you didn't have before to me?
IrvSp
Mar 05, 2018Master
- Walkert20Mar 05, 2018AspirantThanks for the help.
I am seeing the main SSID in which I changed the name and I am seeing one that is associated with the router that is NETGEAR 5g. I have tried to use the same password to connect to it but it will not connect. I am not using the smart connect. I’m not sure I need or will use or know what the 5g SSID is used for. I was worried that it’s associated with the router but I couldn’t log into it.- IrvSpMar 05, 2018Master
Unfirtunately I can't see what you are seeing? I'll need more info. Like 'where' are you seeing this? On a PC as possible connections?
What device sees this? I assume it is a N or AC device? Are you seeing it in your device app or something else?
When you open the Router with Genie on a Browser, and look at the wireless settings. What are they all, 2.4Ghz and 5Ghz, and the same for the Guest accounts? List the SSID's.
I wonder if you are seeing a neighbor's router SSID's?
