Oconner96
Mar 18, 2021Aspirant
New secondary access point capped at 100mbps
New router model:R6080 ISP provided router:zyxel EMG6726-B10A Provisioned speed: 500mbps Wired access point lan to lan setup with cat6 Okay above I’ve provided details of all my specs. I have ran ...
antinode
Mar 18, 2021Guru
Hmmm. Where to start, ...
> New secondary access point [...]
> New router model: [...]
> Wired access point [...]
Are these things all the R6080?
It's called a _wireless_ access point because it provides wireless
access, not because it uses a wireless connection to the main router.
> [...] lan to lan setup with cat6
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Use the Router as a WiFi Access Point Only". Note the suggested wiring
scheme, as well as the device configuration.
> [...] I seem to be having a 100 MB per second cap on my new router.
https://community.netgear.com/t5/x/x/m-p/1711958
> [...] Or could it possibly be a bad router?
It's certainly bad if you wanted something faster.
> [...] Along with trying multiple land ports. [...]
That's the opposite of a SEA port?
