Styks
Feb 03, 2019Aspirant
Night Hawk App
I have the AC1900 Night Hawk router. But when I try to access it with the iOS Night Hawk app, it says the app isn’t supported. Is there a selection in the genie that I need to make?
- Feb 05, 2019
> I have the AC1900 Night Hawk router. [...]
"AC1900" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label.> Model: R7300DST|Nighthawk DST-AC1900 DST Router
Assuming that that's accurate:
https://kb.netgear.com/000055505/
I don't see "R7300DST" in that list.
michaelkenward
Feb 04, 2019Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
There is a manual for the R7300DST somewhere at the end of this link:
>>>>> R7300DST | Product | Support | NETGEAR <<<<<
Styks
Feb 04, 2019Aspirant
Firmware: V1.0.0.70_1.0.25
- antinodeFeb 05, 2019Guru
- StyksFeb 05, 2019AspirantI don’t either. That blows. Seems dumb to call it the NightHawk app if you can’t use it with all the nighthawk routers. Thanks for the list.
