Styks
Feb 03, 2019Aspirant
Night Hawk App
I have the AC1900 Night Hawk router. But when I try to access it with the iOS Night Hawk app, it says the app isn’t supported. Is there a selection in the genie that I need to make?
- Feb 05, 2019
> I have the AC1900 Night Hawk router. [...]
"AC1900" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label.> Model: R7300DST|Nighthawk DST-AC1900 DST Router
Assuming that that's accurate:
https://kb.netgear.com/000055505/
I don't see "R7300DST" in that list.
Styks
Feb 04, 2019Aspirant
Firmware: V1.0.0.70_1.0.25
antinode
Feb 05, 2019Guru
- StyksFeb 05, 2019AspirantI don’t either. That blows. Seems dumb to call it the NightHawk app if you can’t use it with all the nighthawk routers. Thanks for the list.
