maxmonz's avatar
maxmonz
NIghtawk doesn't connect anymore to R7000
Every day I regret to have bought a Netgear router.
This morning it was impossible to access the router admin interface. Internet was on and working but I was unable to access the admin page. It's not the first time. Ridiculous.
So I rebooted the router and now I can access the admin page from browser. But Nightawk says the password I use on browser is not valid so I'm unable to connect Nightawk to my router.
Is there something working with Netgear products? Now what can I do?
  • plemans's avatar
    What actual firmware version are you on?
    have you tried the default login info:
    Default login: admin
    password: password
    all lower case.
    Maybe it updated firmware and reset itself.
    • maxmonz's avatar
      maxmonz
      The router didnn't reset. It's working and I can access the administration interface from a browser. The firmware Is the last. Everything worked until today. The login Page was unreachable from the browser and so the app was unable to connect. I rebooted the router. From browser everything Is ok. The app Is **bleep**ed.
      • plemans's avatar
        maxmonz wrote:
        The router didnn't reset. It's working and I can access the administration interface from a browser. The firmware Is the last.---what actual version are you on? A number is better than "the latest/last" because the r7000 is known to not update regularly.  Everything worked until today. The login Page was unreachable from the browser and so the app was unable to connect. I rebooted the router. From browser everything Is ok. The app Is **bleep**ed.
        You're able to log into it now? Or not?
        You just can't use the app?
        did you try factory resetting and starting over?
