vipgroup
Jun 25, 2025Follower
Nighthawk 7000 as a repeater
Can I configure my R7000 to repeat my wireless SSID from my R6700v3? If so, how do I do it? I want to extend my Wi-Fi signal in my house to areas with weak coverage. Is there a better configuration? ...
Jun 26, 2025Guru - Experienced User
Might checkk the user manual for Repeater mode. Not sure if this model supported that. If you see information in the user manual for it, then it supports it and should have some info on how to set that up.
