i2ikombat
Sep 27, 2016Aspirant
Nighthawk AC1750 setup stalls at routerlogin
Hi everyone. I'm a novice when it comes to this stuff so be nice. ;) I just purchased the Nighthawk AC1750 along with the Netgear CM400 HS Cable Modem in order to replace the jinky one from Comcast. ...
- Retired_MemberSep 27, 2016
When it opens the 2nd tab........ close both tabs.... and type 192.168.1.1
admin
password
go to setup....internet setup.....select use pc MAC address ....apply then power cycle modem router and PC
try clearing browser cache
i2ikombat
Unfortunately that didn't seem to work. As soon as I plug the Ethernet from the computer to the router the browser opens to continue to the genie screen. Genie screen loads with the message, " detecting if there is an existing router..." ( which there is not), the message "checking internet connection, please wait" and when this shows, a second tab opens and begins the same process again. Finally a message is displayed stating, " you are not connected to the Internet."
The modem is working correctly. I am able to connect no problem if I am using just the modem.
Computer is HP 110 desktop running Win10
Retired_Member
Sep 27, 2016When it opens the 2nd tab........ close both tabs.... and type 192.168.1.1
admin
password
