Sundher
Oct 13, 2017Tutor
Nighthawk AC1900 (R6900)
Hi I was using this wifi router along with netgear c3700 wifi modem with com cast xfinity My C3700 ceased working , i have replaced based my modem with Arris SurfBoard SB6190 I'm able to b...
- Oct 19, 2017
Hi Antinode,
Thanks for your reply, I'm able to solve this out with the following actions
1.I disconnected the ethernet cable from modem to router
2. Power off the router and modem
3. I switch on the router and press the reset button for 10 seconds, without connecting it to the modem
4. Once the router boot up I able to see the Factory created SSID is showing up in the WIFI broadcasting list
5. I turn off the router and turn on the modem and wait for it to get established connection with the local node
6. Once connection is established I connected the ethernet cable from Modem to wifi router and another ethernet cable from router to Mac
7. I connected the router admin page and updated the firmware in the modem
8. I also run the setup wizard again to configure the router and the issue got resolved.
Thank you so much for all your help and guidances
Thanks
Sundher
antinode
Oct 13, 2017Guru
> Light indicaator shows its connected to internet but not able to
> browse it , [...]
> [...] but not able to reach the settings page [...]
"not able" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, ...)
can be more helpful than vague descriptions or interpretations.
> [...] even reset is not completely doing the factory reset mean to say
> replacing the factory ssid and password configuration
How do you know that? Again, actual observations, please.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. The User Manual should explain the procedure.
> [...] with another lan cord physical connnected to the router [...]
What is this Ethernet cable connecting to the router? Some computer?
Which OS?
- SundherOct 13, 2017TutorProblem
Not able to connect to interner via r6900 after changing the modem
Observations
Validate the internet is working through new modem - yes via ethernet cable
White led light indicator is showing up
For following
Power
Internet
2.4 ghz
5 ghz
Steps
Tried
Reset the router by pushing the reset button
Router rebooted but ssid still showing the one i configured but not the ones came out of factory setting , I observed this by scanning the wifi
Try to reach setting page by physically connect the laptop with router and try to browse router setting page but getting 404
Thanks- antinodeOct 13, 2017Guru
Did you follow the procedure in the User Manual? "pushing the reset
button" is not a useful description.
> the ones came out of factory setting [...]
Ok. Then that was not a full ("factory") reset.
Does "physically connect" mean that you ran an Ethernet cable from
your "the laptop" to one of the LAN ports of the R6900?
What, exactly, does "browse router setting page" mean? What,
exactly, did you put into the browser's URL box? If you really got a
"404" error, then it might be time to reload the firmware of the R6900.
If you got some other failure, which did not actually say "404", then
please don't try to interpret the actual error, just report it.
> Which OS?
Still wondering.- SundherOct 14, 2017TutorAs per the user instructions I pushed the reset button with help paper clip for 7 seconds
Yes I connected laptop to router via another ethernet cable from laptop to router
Router setting : try access the http://192.168.1.1 or http://192.168.0.1 from chrome browser
I was expecting the web containing access settings to my router got displayed but no web page got displayed with error msg saying network error
OS MAC OS Sirrera
Browser Chrome
Thanks
PS : Responding from mobile device not able to perform inline response
