Sundher's avatar
Sundher
Tutor
Oct 13, 2017
Nighthawk AC1900 (R6900)
Hi    I was using this  wifi router along with netgear c3700  wifi modem with com cast xfinity My C3700 ceased working , i have replaced based my modem  with Arris SurfBoard SB6190  I'm able to b...
  • Sundher's avatar
    Sundher
    Oct 19, 2017
    Hi Antinode,
    Thanks for your reply, I'm able to solve this out with the following actions
    1.I disconnected the ethernet cable from modem  to router
    2. Power off the router and modem
    3. I switch on the router and press the  reset button for 10 seconds, without connecting it to the modem
    4. Once the router boot up I able to see  the  Factory created SSID is showing up in the WIFI broadcasting list
    5. I turn off the router and turn on the modem and wait for it to get established connection with the local node
    6. Once connection is established I connected the ethernet cable from Modem to  wifi router and another ethernet cable from router to Mac
    7. I connected the router admin page and updated the firmware in the modem
    8. I also run the setup wizard again to configure the router and the issue got resolved.
    Thank you so much for all your help and guidances
    Thanks
    Sundher
