19rellimcm37
Feb 26, 2017Aspirant
Nighthawk AC1900 R7000 Questions
I have to upgrade my home wifi ap/router due to lack of firm ware updates and I am interested in puchasing this one. However I have few questions. 1. Does this device support dd-wrt fi...
- Feb 26, 2017
1. Does this device support dd-wrt firmware? --- Yes
2. What is the typical cycle time that Netware will support this device with firmware?
The firmware is fairly mature now and there are actually not that many problems with the firmware. The R7000 appears to be one of NetGear's most popular routers. I would expect firmware support to be supported for several more years given the number in use and the number being sold.
schumaku
Feb 27, 2017Guru - Experienced User
19rellimcm37 wrote:1. Does this device support dd-wrt firmware?
Might happen there are DD-WRT builds available for the R7000 platform. If you can't figure out I'm not convinced you should consider alternate firmware at all.
19rellimcm37 wrote:2. What is the typical cycle time that Netware will support this device with firmware?
Usually then security and some operational issues occur. You can build a a time line if oyu desperatley based on the information available from Search Netgear Support:R7000 Firmware Version - of corse, this deos not cmpare to the almost weekly builds some geeks are maitaning and building.
