19rellimcm37
Feb 26, 2017Aspirant
Nighthawk AC1900 R7000 Questions
I have to upgrade my home wifi ap/router due to lack of firm ware updates and I am interested in puchasing this one. However I have few questions. 1. Does this device support dd-wrt fi...
- Feb 26, 2017
1. Does this device support dd-wrt firmware? --- Yes
2. What is the typical cycle time that Netware will support this device with firmware?
The firmware is fairly mature now and there are actually not that many problems with the firmware. The R7000 appears to be one of NetGear's most popular routers. I would expect firmware support to be supported for several more years given the number in use and the number being sold.
bpbp
Mar 17, 2017Aspirant
Good afternoon, how did you accomplish this? The zip file comes in the wrong format and cant seem to find out how to make that work. Thanks!
IrvSp
Mar 17, 2017Master
bpbp wrote:Good afternoon, how did you accomplish this? The zip file comes in the wrong format and cant seem to find out how to make that work. Thanks!
You are new to this thread. What router, what file did you get, and WHAT is the extension?
- bpbpMar 17, 2017Aspirant
This is in regards to the AC1900 R7000. The firmware I am trying to flash is v380.65 from xvtx. The file extension that comes in the zip is .trx. I am being told that I need a .chk file.
Thanks!
