Sytruck
Jan 25, 2018Aspirant
Nighthawk AC1900 Slow wired speeds
Nighthawk AC1900 Smart WiFi Router. Firmware V1.0.9.18_1.2.27 Windows 10 After installation (jan 8, 18), leaving everything at their default settings except login password, WiFi name and password...
- Feb 02, 2018
I went ahead and "paper clipped" the router and based on signal strength as measured by TIVO things improved considerably. I'm now at 50% which I've never seen before. My hardwired speed has not changed either. SweetSpot measures 86 Mbps @ nearest laptop, to 19 at the TIVO. I can live with that...
Thanks for all the help.
KamalaKumar
I purchase this Router on 08-01-2016 Now the WiFi connection often cut off and again connected by itself. My Comcast Xfinity Internet connection is uninterrepted work. My Desk top connected with cable so it is working fine. Only the R6900 Nighthawk AC1900 .Smart WiFi Router is problem. It works only 17 Months. After rebooting sevaral times no use.
