Sytruck
Jan 25, 2018Aspirant
Nighthawk AC1900 Slow wired speeds
Nighthawk AC1900 Smart WiFi Router. Firmware V1.0.9.18_1.2.27 Windows 10 After installation (jan 8, 18), leaving everything at their default settings except login password, WiFi name and password...
- Feb 02, 2018
I went ahead and "paper clipped" the router and based on signal strength as measured by TIVO things improved considerably. I'm now at 50% which I've never seen before. My hardwired speed has not changed either. SweetSpot measures 86 Mbps @ nearest laptop, to 19 at the TIVO. I can live with that...
Thanks for all the help.
Sytruck
Jan 31, 2018Aspirant
I'm not on 1.0.9.26 anymore. The link you sent put me on V1.0.9.26_10.2.31
And FYI speeds are still normal.
Thanks.
michaelkenward
Feb 01, 2018Guru - Experienced User
Same thing really. The first bit is what matters.
- SytruckFeb 02, 2018Aspirant
