Sytruck's avatar
Sytruck
Nighthawk AC1900 Slow wired speeds
Nighthawk AC1900 Smart WiFi Router. Firmware V1.0.9.18_1.2.27 Windows 10   After installation (jan 8, 18), leaving everything at their default settings except login password, WiFi name and password...
  • Sytruck's avatar
    Sytruck
    Feb 02, 2018
    I went ahead and "paper clipped" the router and based on signal strength as measured by TIVO things improved considerably. I'm now at 50% which I've never seen before. My hardwired speed has not changed either. SweetSpot measures 86 Mbps @ nearest laptop, to 19 at the TIVO. I can live with that...
    Thanks for all the help.
