FBFeins
Nov 30, 2025Aspirant
Nighthawk AC1900 Smart WiFi Router (R6900P) in AP Mode, Second R6900P
All connections are Ethernet. Buried Ethernet and feeder cable to buildings #2 and #3; Ethernet and utility feeder cabling are ~12" separation as appropriate. Router is Nighthawk X6S, AC3600 (Mo...
Dec 01, 2025Guru - Experienced User
Recommend setting 1st router to manual channesl 1 and 40, set 2nd router to far appart channels 11 and 48 or one of the higher 5Ghz channels. Or vice versa.
