hood_ornament
Nov 26, 2020Follower
Nighthawk AC1900 WiFi Unable to Connect to AC750 WiFi Range Extender
We had been bad speed using the router that our ISP provided so we bought the Nighthawk AC1900 WiFi Cable Modem Router. My Range Extender is AC750 WiFi Range Extender, Model EX3110 The router is on...
- Nov 26, 2020
a couple things.
1. The device link light turns on if a device connects to the extender
2. the EX3110 isn't a mesh extender.
3. Did you set a seperate ssid for the extender? if so, simply connect a device to its ssid
4. Since the ex3110 isn't a mesh extender, if you set the ssid the same as the router, your devices will tend to be "sticky". Meaning they won't roam like a mesh device will.
Nov 26, 2020Guru - Experienced User
a couple things.
