Patricklewis82's avatar
Jul 11, 2023
Nighthawk ac1900
My router quit putting out wifi. So all lights are on as they should be. Firmware is up to date, 30-30-30 rest has be done, and there is an address from the modem. It just will not put out internet connection. Not sure what is wrong with it.
  • FURRYe38's avatar
    Try a 10 second press on the reset button in back then release. Setup from scratch using a wired PC and web browser connected at 192.168.1.1
    What is the model # of this router? R####?
    • Patricklewis82's avatar
      Patricklewis82
      Problem is I don’t have a plug in desktop. I cannot do that type of set up. Everything is wifi.
        Patricklewis82
        I went through the new set up through the app and it has not internet connect, it’ll detect the router but won’t connect to the internet
