Jmvlg
Jul 16, 2024Aspirant
Nighthawk AC4000 3x3 tri band WiFi Router—going off and on with ATT fiber Giga, mainly Apple devices
Hi, my router has 4 years and since some time already, the internet goes off and disappears from the WiFi list of available networks on Apple. I reset quite often the fiber, modem, router boxes. Problem remains. ATT has this security free service (firewall?!?!) turned ON, could it be the problem? Should I switch it OFF? I believe I had donde that too and no big difference on R8000P going OFF and ON, irresponsiveness. Thank you
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channel configurations are currently set on the router? Try 1 and 40.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message- JmvlgAspirant
Here:
- Mfr and model# of the Internet Service Providers: Arris, BGW210-700, SW ver. 4.26.11; AT&T Miami-Florida- channel configurations currently set on the router?: 2.4GHz on 3, 5GHz on 48 -- I will change it and run a congestion detection for each band.
Thanks.
Try channel 1 and 40.
Also check the ISP modem. That's a gateway modem with built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
