Melissa3
Apr 10, 2021Tutor
Nighthawk App Can’t Find CM1200
I’ve been unable to get the app to find my modem. I’ve had it for three months and have been able to access internet with no issues but the app still cannot find and connect to the modem. I’ve read ot...
- Apr 10, 2021
The app does not support modems, as far as I know.
antinode
Apr 10, 2021Guru
> I've been unable to get the app to find my modem. [...]
"unable" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] the app still cannot find and connect to the modem. [...]
Regarding "cannot", see "not a useful problem description [...]",
above.
> [...] I've read other threads [...]
Thanks for the helpful links.
> [...] none of it works.
"it"? Regarding "not work", see "not a useful problem description
[...]", above.
Is there anything in the instructions for "this app" which mentions a
_modem_, or does everything discuss a _router_? I see, for example:
Nighthawk App makes it easy for you to install your router [...]
https://www.netgear.com/home/services/nighthawk-app/
Visit http://netgear.com/support , put in your (modem) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "app". Find anything? Further reading should reveal how to
manage the modem using a web browser (not any app).
https://en.wikipedia.org/wiki/RTFM
Simple, but often effective.
Melissa3
Apr 10, 2021Tutor
I explained that the nighthawk app is not finding my modem. Which explained what I meant by “unable.” Please do not be rude. I’m here for help. I also did not save threads and do not know how to share them here. Just as with your issue with me saying “unable” I also explained specific things I tried from those threads. Did you miss that as well? I have explained as far as I am able: nighthawk app cannot find modem. Exactly what the app tells me. Exactly what I’m explaining here and in my original post. I’m sorry I’m not explaining the way you wish but this is how I know how to.
