Melissa3
Apr 10, 2021Tutor
Nighthawk App Can’t Find CM1200
I’ve been unable to get the app to find my modem. I’ve had it for three months and have been able to access internet with no issues but the app still cannot find and connect to the modem. I’ve read ot...
- Apr 10, 2021
The app does not support modems, as far as I know.
microchip8
Apr 10, 2021Master
Melissa3
Apr 10, 2021Tutor
Interesting! The modem came with an insert that mentioned using the app.
- antinodeApr 10, 2021Guru
> I explained that the nighthawk app is not finding my modem. Which
> explained what I meant by "unable." [...]It really didn't. If I wanted to do with my own equipment, what you
did with yours, then what, exactly, should I do? Fetch and install some
version of the Nighthawk App on some kind of mobile device like your
(unspecified) device, and then, _what_, exactly?> [...] the app still cannot find and connect to the modem. [...]
A clear description of what _does_ happen would be more useful
than a vague description of what does _not_ (or "cannot") happen.> [...] Please do not be rude. [...]
Please do not expect to deal with psychics who can see what you did,
and what happened when you did it.
> [...] I also explained specific things I tried from those threads.
> [...]Describing what you did to try to solve the problem is less helpful
than describing the actual problem would have been.> [...] nighthawk app cannot find modem. Exactly what the app tells me.
> [...]The app displayed a message which said, "cannot find modem"? Or does
"exactly" mean something to you which is different from what it means to
me? Which part of "actual actions" or "actual results (error messages,
[...]" was unclear?> [...] The modem came with an insert that mentioned using the app.
Can't see that document, either.
- Melissa3Apr 10, 2021TutorThe other guy seemed to understand quite clearly. But thanks for wasting my time.
