jKat
Dec 12, 2018Aspirant
Nighthawk App (formerly up) not working
Downloaded the Nighthawk App, does not allow to log in. I enter the utilities username and password, switches over like it’s going to do something then kicks me back to login screen. Genie App does wo...
- Dec 13, 2018Solved: updated the firmware and problemo solved!
IrvSp
Dec 13, 2018Master
"enter the utilities username and password"?
What are you using? Should be the same USERID and PASSWORD used for Genie and a Browser. NightHawk doesn't have its own set.
