jbenjesus
Jul 12, 2018Guide
Nighthawk App (formerly up)
I just downloaded the app on my smartphone and upon installation and setup it says my Nighthawk router is not compatible (R7500v2).
What is the problem?
- Jul 12, 2018
Here is the list of supported routers but we are constantly updating.
https://kb.netgear.com/000055505/Which-routers-support-the-NETGEAR-Nighthawk-app
DarrenM
jbenjesus
Jul 12, 2018Guide
This is my connect error message
- eguerboxJul 12, 2018TutorHi,
The r7500v2 was recently updated to Firmware Version 1.0.3.36. The change logs says that this update allows the router to work with the app.
I think Netgear needs to update the app in order to support the router because I'm having the same issue.- schumakuJul 12, 2018Guru - Experienced User
eguerbox wrote:
Hi,
I think Netgear needs to update the app in order to support the router because I'm having the same issue.Perfectly correct - https://kb.netgear.com/000059531/R7500v2-Firmware-Version-1-0-3-36 release notes state
New Features and Enhancements:
- Supports the Nighthawk app version 2.1
And (for example) the Android version of the Nighthawk App is on some v2.2 for a while already.
DarrenM ... what gives?
AbhayB ... more problems, still one big mess, isn't it?
- DarrenMJul 13, 2018Sr. NETGEAR Moderator
I will double check what is going on with this.
DarrenM
- DarrenMJul 12, 2018Sr. NETGEAR Moderator
DarrenM
- jbenjesusJul 12, 2018Guide
Thank you! That completely answers the question. My Nightawk AC2350 router R7500v2 is not on the compatability list for the Nighthawk App.
