jbenjesus
Jul 12, 2018Guide
Nighthawk App (formerly up)
I just downloaded the app on my smartphone and upon installation and setup it says my Nighthawk router is not compatible (R7500v2).
What is the problem?
- Jul 12, 2018
Here is the list of supported routers but we are constantly updating.
https://kb.netgear.com/000055505/Which-routers-support-the-NETGEAR-Nighthawk-app
DarrenM
jbenjesus
Jul 12, 2018Guide
This is my connect error message
eguerbox
Jul 12, 2018Tutor
Hi,
The r7500v2 was recently updated to Firmware Version 1.0.3.36. The change logs says that this update allows the router to work with the app.
I think Netgear needs to update the app in order to support the router because I'm having the same issue.
- schumakuJul 12, 2018Guru - Experienced User
eguerbox wrote:
Hi,
I think Netgear needs to update the app in order to support the router because I'm having the same issue.Perfectly correct - https://kb.netgear.com/000059531/R7500v2-Firmware-Version-1-0-3-36 release notes state
New Features and Enhancements:
- Supports the Nighthawk app version 2.1
And (for example) the Android version of the Nighthawk App is on some v2.2 for a while already.
DarrenM ... what gives?
AbhayB ... more problems, still one big mess, isn't it?
