sliepa
Jul 31, 2021Aspirant
Nighthawk AX8 firmware update wifi issues
So I complete a firmware update yesterday and now the system can't recognise the 2.4 and 5 G wifi. I also have many smart devices connected and now they don't connect properly. I see a new smart se...
Jul 31, 2021Guru - Experienced User
What actual router do you have? (look on the label)
Anytime theres an issue after a firmware change, the first thing I'd try would be a factory reset and reinstall. sometimes the firmware can change enough that an old setting can cause issues.
