tayloma4's avatar
tayloma4
Nighthawk C7000 Cable Modem Router and R7000 Smart Wifi Router
I just purchased a AC1900 Wifi Cable Modem Router model number C7000.  I have a fairly large house and I want to extend my wifi signal.  Can I use the AC1900 Smart Wifi Router model number R7000 for this?  My intent is to connect the two via an ethernet cable.  I would then also connect a Playstation PS3 to the R7000 router via an ethernet cable also.  Not sure if this is the way to do this or not.  Am I doing this correctly or is there a different setup I could use?
Thanks for your help..
