carylynnj777
Dec 22, 2016Aspirant
Nighthawk DST AC1900 - Can't find Internet
I just received my new Nighthawk DST AC1900, followed the set up instructions and was unable to complete the set up. I have checked my Internet connection, talked to my ISP (my connection is plug an...
- Dec 22, 2016Yes I just spent 2 hours with Netgear support. Used both my previous router and laptop Mac addresses, multiple resets both hard and soft, and the Internet LED remains solid amber with no Internet connectivity. We also did a firmware upgrade. NG support told me to return it.
michaelkenward
Dec 22, 2016Guru - Experienced User
