SntaCruz83
Mar 15, 2018Tutor
Nighthawk Guest Network Limitation
Nighthawk R7000 Firmware Version V1.0.9.18_1.2.27 I wanted to set up some IP cameras and other devices on a guest network that wouldn't have access to my actual local network. However, it seems...
JamesGL
Mar 19, 2018NETGEAR Employee Retired
Hi SntaCruz83,
Yes, that is the only option it has. Once enabled, devices connected to the guest network will have access to local network.
