PRA_Gyros's avatar
May 18, 2019
Nighthawk M1 20 user limit?
The nighthawk M1 specks are the perfect solution to wifi our airport project except for one drawback.
The 20 user limit. We need maybe 250 max users at one time to distribute to our outdoor mesh system.
Is that limit set in the M1 box/software or by the carrier?
Has anyone figured out how to use it as a IPS with more than 20 users?
We need a solution for 250 users with a directional antenna as our signal strength sucks and won't have cable for 6 months to a few years as we have been hearing 6 months for at least two years.
The only other solution I could find, so far, is CradlePoint's AER2200 sim-card router, but it's $1,200.
  • A work-around for the MAC restriction to about 20 clients would be adding an Ethernet NAT router, like a consumer Nighthawk router, or a BR500 - so _all_ clients appear to come from the very same device.
    Next limits you might hit are the number of concurrent NAT sessions by single MAC and by all MAC addresses. 250 clients on a single mobile "router" might be rather challenging.
