soonerchad
Jan 20, 2016Tutor
Nighthawk New Install Black Ops 3 Moderate Nat
I have a Netgear N450 modem/router. I just bought a Nighthawk R7000. I play Black Ops 3, the problem I was having before the Nighthawk was lag. I bought the Nighthawk with hopes of helping said lag. ...
- Jan 21, 2016
I'm assuming that you have a CG3000D modem/router. Try looking for a bridge mode setting under the advanced options. If there's nothing there, then try going to http://192.168.0.1/RgNatControl.asp. Use your modem's IP address if it's not 192.168.0.1. There's supposed to be an option to turn off NAT. This should be equivalent to enabling bridge mode. Read about this here (link).
soonerchad
Jan 20, 2016Tutor
Factory reset both the modem and router. UPNP was enabled, no port forwarding. Ticked the open on the Nat settings. Tried Black Ops, still Moderate. Restarted modem, router, and Xbox One, and tried again. Still moderate. Any other ideas?
