soonerchad
Jan 20, 2016Tutor
Nighthawk New Install Black Ops 3 Moderate Nat
I have a Netgear N450 modem/router. I just bought a Nighthawk R7000. I play Black Ops 3, the problem I was having before the Nighthawk was lag. I bought the Nighthawk with hopes of helping said lag. ...
- Jan 21, 2016
I'm assuming that you have a CG3000D modem/router. Try looking for a bridge mode setting under the advanced options. If there's nothing there, then try going to http://192.168.0.1/RgNatControl.asp. Use your modem's IP address if it's not 192.168.0.1. There's supposed to be an option to turn off NAT. This should be equivalent to enabling bridge mode. Read about this here (link).
TheEther
Jan 20, 2016Guru
Did you put your modem into bridge mode? You need to do that in order for the Nighthawk to function as the only router. Otherwise, uPnP won't work properly.
soonerchad
Jan 21, 2016Tutor
Thats kinda what I was thinking but from what I have read and see there is no bridge mode on this modem. Thanks for the reply! Maybe I need to buy a new modem???
- TheEtherJan 21, 2016Guru
What's the model of your modem/router?
