Augie1711's avatar
Nov 06, 2021
Nighthawk R000
The webpage at https://xx.xxx.xxx.xx:xxxx/top.html might be temporarily down or it may have moved permanently to a new web address.
Is anyone getting this error at the top of the page - I do not have the Basic or Advance Tabs showing.  What causes this to happen?  Thank you in advance!
  • Thank you all.  I guess the solution is to just wait.
  • plemans's avatar
    what router do you have?
    firmware on it?
    What modem/gateway is it connected to?
    Got a screen snip of the error?
    • Augie1711's avatar
      Augie1711
      Tutor
      I have a nighthawk R9000...  Ironically, the problem is non existent now.  I appreciate your questioning.  I did not have a pic.  I was focused on resolving an issue and did not know what caused me to lose access to the tabs and advanced settings.  It self resolved but have never expierienced this issue.  Thank you1
