footballfan500
Feb 19, 2021Aspirant
Nighthawk R6400 dropping connection
I purchased my router several years ago and most of that time it has had a problem randomly dropping the internet connection requiring me to reboot the router. I logged directly into the router to change the channels on the 2G and 5G aftering using the Netgear Wifi app to detect the best channel with less traffic. I have also checked to make sure I have the latest firmware. I am tired of rebooting it and don't know whether the router is no good or if there is something I can do to resolve this. Sometimes I can go 5 or 10 days before I have to reboot the router other times it is daily.
Does anyone have any ideas before I go out and buy a $300 gaming router from another brand?
What actual firmware number are you on? the latest isn't always the best.
What modem is it connected to?
Since it started, have you tried a factory reset and reinstall?
- footballfan500AspirantI have not tried a factory reset. I am on v1.0.1.62. I connect my Verizon Fios directly via ethernet.
There is a newer version. I'd try installing that over a hardwired connection, then the factory reset/reinstall.
