ronstone's avatar
ronstone
Follower
Dec 10, 2020
Nighthawk R6400v2 daily says the password doesn’t work. Kicks everyone off
Using an Arris SB8200 modem, spectrum 200x10 internet. Firmware v1.0.4.102 on router.
Once a day I try to search something on my phone and it’ll just keep spinning saying I have no internet access. Then when I go to the WiFi page it’ll say that the password is incorrect on my device. The password doesn’t change from before.
If I unplug my modem it’ll restart and the password works fine, but in a day the problem will repeat. I have reset my router 5 of the last 7 days.
Typically the problem comes when my girlfriend and I are working during the day. We both work from home at the moment as most people do.
Any other information required feel free to ask.
1 Reply
  • plemans's avatar
    Try this.
    reinstall the firmware have a hardwired version, then factory reset and do a clean install (not from backup)
    Reason why is if something is corrupt in the firmware a firmware reinstall will overwrite it. Doing a factory reset and clean install will ensure its not a setting causing the issue.
