Namo
Nov 02, 2023Initiate
Nighthawk R6700 v3 router not relaying wifi signal
My R6700v3 router is wifi stopped sending wifi signal there are onlt first 2 leds lighted. I logged into my Nighthawk phone app but no problem shown there. Tried power cycling but Wifi signal doesn't show on the devices. I happened all of a sudden and the wifi signal went down
- The LEDs for wifi are also button you can press to enable or disable the wifi. Did you try it?
- microchip8MasterThe LEDs for wifi are also button you can press to enable or disable the wifi. Did you try it?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router- NamoInitiateProblem got resolved shortly when I found about a wifi signal start/stop button.
Thanks a lot for your assistance.- FURRYe38Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
