future_vision
May 24, 2022Aspirant
Nighthawk R6700v3 PPPoE setup for Fidium fiber?
I have new Fidium service but opted to use my Netgear Nighthawk R6700v3 router instead of their router which I understand is pretty locked down. Problem is I can't seem to get internet working over W...
May 24, 2022Guru - Experienced User
Try using DHCP instead of PPPoE on the NG router...
future_vision
Firmware Version
V1.0.2.52_1.0.39
Fidium ONT
AdTran SDX622v XGSPON ONT
Supposedly authentication happens with PPPoE. They are switching over to MAC and serial in the near future.
- FURRYe38May 24, 2022Guru - Experienced User
Can they move the PPPoE to the ONT and then let the NG router use DHCP?
- future_visionMay 24, 2022Aspirant
I don't believe so. I'm not even sure I can access the ONT
- FURRYe38May 25, 2022Guru - Experienced User
For this kind of ISP service, the R6700v3 is using older generation hardware so even if you got this to work, it may not work well or to spec. I would recommend you get into a newer generation router to use with this ISP service.
