Pyrovespin
Sep 15, 2026Follower
Nighthawk r6700v3
I recently switched to starlink and I don't have a ipv4 public address as they use a cgnat system. I have a server setup for personal use behind my router and I cannot connect to it using the port fo...
Sep 15, 2026Guru - Experienced User
Check with starlink on what IPv6 is supported, required or configuration is needed on the router.
FYI, R6700 series is kinda old now so IPv6 on the router may not be up to specs for IPv6 configurations of today. May need something newer.
Use the ISP router if one is available.
