sidelinellc's avatar
sidelinellc
nighthawk r700 with Magic jack plugged directly into USB doc 3 ?--can it be done as with pc
Id like to eliminate the ethernet cable and plug the MJ directly into my nighthawks usb such as you would perform with a pc.  advice? havnt found much info on it. thank you
  • shadowsports's avatar
    shadowsports
    Mar 30, 2016
    This type of device is not supported.
