SillyMan's avatar
SillyMan
Nighthawk R7000 -- WIRELESS speeds FASTER than wired speeds
Hi this is my first post here and it's a weird one for me. I've been running QoS for a while without issue but it seems like after an update and I'm not sure which one my Ethernet speeds have severel...
  • ElaineM's avatar
    ElaineM
    Jul 21, 2017
    Have you tried changing the Ethernet cable?
    What's your speed when you bypass the router?
    Did you try all LAN ports on the router?
    By the way, did you reset the route rafter firmware upgrade?
