SillyMan
Jul 17, 2017Aspirant
Nighthawk R7000 -- WIRELESS speeds FASTER than wired speeds
Hi this is my first post here and it's a weird one for me. I've been running QoS for a while without issue but it seems like after an update and I'm not sure which one my Ethernet speeds have severel...
- Jul 21, 2017
Have you tried changing the Ethernet cable?
What's your speed when you bypass the router?
Did you try all LAN ports on the router?
By the way, did you reset the route rafter firmware upgrade?
SillyMan
Jul 24, 2017Aspirant
So far everything is working properly and Ethernet speeds are fast the way it should be. Only thing that i have noticed is that when i run say multiple consoles that if i have a stream playing in the background it might suffer a little qualityor pause for a second. Not a big deal considering what was happening before. Im sure QoS could help with that but im not sure i want to mess with that setting again. Seemed to be more hassle than its worth. So i think its safe to say that the factory reset did the trick for me.
thank you
ElaineM
Jul 25, 2017NETGEAR Employee Retired
Thank you very much for the feedback.
