claretblue
Nov 20, 2016Aspirant
Nighthawk R7000 and FTTH slow download speeds but high upload speeds (wired connection)
Hi, Just purchased a AC1900 R7000 and when plugged into my TalkTalk UFO Fibre broadband I can only get 45-50 download speeds although the upload speeds are circa 700. This is on a wired connecti...
- Nov 20, 2016
Solved: it turns out when I originally set this up via set up wizard it detected I had PPPoE when in fact this was not necessary and when I removed need to authenticate with Id and password the correct speeds returned. I now have good up and down speeds directly through this router and can box up the Substandard one the TakkTalk supplied (HG635)
claretblue
Neil_McCutcheon
Dec 04, 2016Aspirant
I am also on TalkTalk UFO. I have to connect using PPPoE and am struggling to achieve more than 500Mbit whereas the Huawei router would achieve 870Mbit down and ~940Mbit up.
Are you on the Domestic or Business service?
Are you still getting a healthy data rate?
I would like to hear how it's going for you now.
