Narkis's avatar
Narkis
Nighthawk R7000 and Playstation Now
Hello there.    I have a Nighthawk Router and I have been having trouble with trying to get connection with my Playstation Now Account,  When using the nighthawk it says my connection isn't good en...
  • JamesGL's avatar
    JamesGL
    Jun 26, 2016
    Hi Narkis,
    Reset the router after the update and manually reconfigure it. If you are using the QoS, make sure to set the priority of the PlayStation to High if you want it to have more priority with the bandwidth.
