Narkis
Jun 17, 2016Aspirant
Nighthawk R7000 and Playstation Now
Hello there. I have a Nighthawk Router and I have been having trouble with trying to get connection with my Playstation Now Account, When using the nighthawk it says my connection isn't good en...
- Jun 26, 2016
Hi Narkis,
Reset the router after the update and manually reconfigure it. If you are using the QoS, make sure to set the priority of the PlayStation to High if you want it to have more priority with the bandwidth.
Narkis
Jun 30, 2016Aspirant
Hello updated my firmware and reset the router seems to have worked, sorry for the late response I've been busy working and had no chance to get to my PC,
Thanks again for all the help and fast response on my issue
- JamesGLJun 30, 2016NETGEAR Employee Retired
Hi Narkis,
Thank you for the feedback. It's my pleasure helping you.
