tony-h's avatar
tony-h
Nighthawk R7000 as a base station
hello  new here i have nighthawk r7000 router i would like to set it up as base and use older d-link dr-628 as extender but dont want to disable security options on nighthawk base would appreciate...
  • FURRYe38's avatar
    Ok, then leave the R7000 as the main host router running router mode.
    The only way to use the DIR-628 aside from router mode is this: LAN to LAN AP mode
    http://forums.dlink.com/index.php?topic=40856.0
    You would place the 628 in a remote location on 2nd or 3rd floors. This will need be LAN wired from the main host router to the 628 at the remote location.
