tony-h
Apr 25, 2017Aspirant
Nighthawk R7000 as a base station
hello new here i have nighthawk r7000 router i would like to set it up as base and use older d-link dr-628 as extender but dont want to disable security options on nighthawk base would appreciate...
- Apr 25, 2017
Ok, then leave the R7000 as the main host router running router mode.
The only way to use the DIR-628 aside from router mode is this: LAN to LAN AP mode
http://forums.dlink.com/index.php?topic=40856.0
You would place the 628 in a remote location on 2nd or 3rd floors. This will need be LAN wired from the main host router to the 628 at the remote location.
tony-h
yes :smileyhappy: isp modem-netgear-dir628
i want the dir to boost wireless signals to remote rooms
now just curious about config settings on netgear if lan to lan is onl option i can run a cable i just want to extend wireless range to 2nd and 3rd floors
Apr 25, 2017Guru - Experienced User
