MaxDockx
Jun 20, 2017Aspirant
NIghthawk R7000 as repeater/extender
Hello, We moved to a new house and we got a new router/modem from our internet/digital tv/phone provider. It is located in a small room where the electricity cabinet is. There are 4 utp ports...
- Jun 22, 2017Yes
Jun 20, 2017Guru - Experienced User
It possible that it may work then again, may not due to the processing and lower wireless performances when using extender or repeater modes and with the processing involved. Any chance you can use the R7000 as a LAN to LAN wireless AP? Would be best if you could connect this way or if the TV has a LAN port in back, use the LAN port for best wired performances.
Check the R7000 UI for modes of operation. There maybe AP, Repeater or Extender modes listed.
- William10aJun 20, 2017Master
Youu are correct the r7000 has a access point or a bridge mode but no wireless repeater mode.
Here is the manual http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf
Page 134 is where the manual starts with instructions the access point would be the best mode to use.
