Cosmro
Jun 09, 2018Aspirant
Nighthawk R7000, Blinking Internet LED with connected ethernet cable, no WI-FI and internet access
Hello, long story short, I tried logging into my router with admin and password but it kept going to the Password Recovery page but whenever I enter the right serial number several times, the continue...
- Jun 13, 2018Sorry for not replying in three days, I wanted to take a break from the situation but I just fixed the router miraculously. The main problem was that the DHCP was not enabled for "Wi-Fi" and it took one click to solve the whole problem. Thank you for your time in helping.
Cosmro
Jun 10, 2018Aspirant
It's a Technicolor TC8717T Docsis 3.0 Wireless Telephony Cable Modem
All LED lights are lit up on the modem with no constant blinking
I have tried out the method and I cannot recieve any connection and the light remains blinking
michaelkenward
Jun 10, 2018Guru - Experienced User
That looks like a modem-router. The clue is the stack of LAN ports on the back.
This means that you are trying to set up two routers on your network, which is a recipe for chaos.
Your best bet is to work out how to put the Technicolor TC8717T into "modem only" (bridge) mode or, if that is not possible, use the R7000 as an access point.
- TicaJun 10, 2018Aspirant
A transformer blew in my neighborhood early Saturday morning and knocked my R7000 off-line. I could not get it to fully boot afterwards, it just hung with some dim leds and I was ready to toss it . Tried multiple resets without success. They say it does not matter, but I unplugged the power supply from the back, then I pressed the power on button twice to drain anything left and let it sit for 5 minutes. I then powered on and continually depressed the reset button for 30-40 seconds until I saw the flashing power led. I then used windows tftp instead of the external program and restored firmware using the command line technique that is discussed on these pages. That did not work the first two attempts but finally I saw the router start sending a few bytes back to the PC. I then rebooted and waited and after 2-3 minutes, it seemed to slowly reprovision itself and I was able to log in to the router admin GUI from a wifi browser and reprogram the settings. Maybe I just got lucky. and this would not work for someone else.
- michaelkenwardJun 10, 2018Guru - Experienced User
That is truly shocking news that sparks off many thoughts.
- CosmroJun 13, 2018AspirantSorry for not replying in three days, I wanted to take a break from the situation but I just fixed the router miraculously. The main problem was that the DHCP was not enabled for "Wi-Fi" and it took one click to solve the whole problem. Thank you for your time in helping.
