skdmark
Sep 29, 2016Aspirant
Nighthawk R7000 does readycloud override readyshare?
I just updated the firmware on my Nighthawk R7000 and decided to try the ReadyCloud option. We have used ReadyShare to access drives on our local network for years. However, once I set up ReadyCloud...
- Sep 30, 2016
Hi skdmark
Welcome to the community!
I have no problems accessing ReadyCloud and local access at the same time.
After firmware update did you factory reset the router? If you have not, kindly do so.
Once done, reconfigure the router just like how it was then verify if you can access it both.
ElaineM
Sep 30, 2016NETGEAR Employee Retired
Hi skdmark
