skdmark's avatar
skdmark
Nighthawk R7000 does readycloud override readyshare?
I just updated the firmware on my Nighthawk R7000 and decided to try the ReadyCloud option. We have used ReadyShare to access drives on our local network for years.  However, once I set up ReadyCloud...
  • ElaineM's avatar
    Sep 30, 2016
    Hi skdmark
    Welcome to the community!
    I have no problems accessing ReadyCloud and local access at the same time.
    After firmware update did you factory reset the router? If you have not, kindly do so.
    Once done, reconfigure the router just like how it was then verify if you can access it both.
