someara's avatar
someara
Nighthawk R7000 dropping connection
I have had issues with this router since we purchased it! We purchased it in January 2022.
My kids have complained that the xbox no longer works as well as it did with the basic router from Spectrum. We use spectrum cable internet. I have the NightHawk in the same room as I had the spectrum router, only instead of under the desk it is out in the open room. Firmware version is V1.3.1.64
When it 'drops' connection, the LED lights on the router are all still glowing white. But in the wifi connections it will say "no internet". Yesterday i just kept disconnecting the wifi connection on my laptop and reconnecting to get internet back. What a GIANT PIA when you work from home as a software consultant - internet is a requirement! I was trying to do a MS Teams meeting when it kept dropping.
The router is connected to Spectrum's TM1602 Modem.
What am i missing?!
I have been super unhappy with this router as well!
  • FURRYe38's avatar
    What CAT# LAN cable are you using between the modem and router? CAT6 is recommended.
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Enable IPv6 Auto Detect on the router.
    Is SIP ALG enabled or disabled on the router?
    Might update FW:
    https://community.netgear.com/t5/Nighthawk-WiFi-Routers/New-R7000-Firmware-Version-1-0-11-134-Released/td-p/2197473/jump-to/first-unread-message
    Factory reset and setup from scratch after FW is updated.
    • someara's avatar
      someara
      I would love to answer these questions for you, but have NO idea how to.
      How do i know what kind of cable it is? It is the yellow ethernet cable that came with the router.
      How do i check the channels?
      And what does all this mean - i am not a technical person - i am a functional software consultant, so this network stuff is challenging for me:
      Enable IPv6 Auto Detect on the router. - how do i do this
      Is SIP ALG enabled or disabled on the router? _ how do i know?
      • FURRYe38's avatar
        There will be printing on the cable that will or should have a CAT# there.
        Log into the routers web page at 192.168.1.1 using a PC and web browser.
        Channels will be under Basic/Wireless settings.
        IPv6 will be under Advanced Tab/Advanced
        SIP ALG will be under Advanced Tab/Setup/WAN setup.
        If needed. find someone that can help you with this.
