tmiprov
Oct 10, 2019Aspirant
Nighthawk R7000...Ethernet connections works fine, but Speedtest.net test on Ethernet port fails
What you download is a zip file. Did you expand it? The .chk file is inside the zip file.
- myerswMaster
More info.
What do you mean fails? Slow, doesn't work, etc
Explain what you have done. Have you recently updated the firmware?
What is the firmware version? A number, not just something like latest.
Are you experiencing any other issues?
- tmiprovAspirant
Hi Bill,
Thanks so much for helping me out.
Being that I'm not home with my router now, I can't obtain the firmware version until later in the day which I will do.
In the meantine, here is the problem...
When I connect an ethernet cable from anyone of my 4 router ports to my PC, I get a solid internet connection (this is with wifi disabled). I'm able to browse and do whatever I want.
During this connection, if I run a speedtest, I get practically nothing for download (.5M) and upload.
If I remove the ethernet from my router and connect it directly to my cable modem, then run the same speedtest, I get a 100M download.
Is there a reason why this happens?
My other issue, if I don't have any ethernet connections from my router to a client, I still see "wired" devices on my Nighthawk App. This is in addition to any 2.4GHz and 5GHz devices that appear as connected devices.
Thanks so much Bill
- tmiprovAspirant
Hi Bill,
Just to follow up, my firmware version is...
V1.0.9.88_10.2.88
Thanks again!
